After 3 solid days of wrenching, the Colt Cams 262* grind and the LCE Lightweight Crankshaft Pulley are in! I was pressed for time so no photos... but not like it would have helped much. If you are reading this to figure out how to put them in, refer to the FSM for detailed instructions. You'll have to take off the upper intake/plenum, timing belt, radiator, and the crankshaft pulley just to swap out cams. It's a very involved job with a lot of checking, double-check, and triple checking as well as a dreaded valve adjustment.
The power is really there at 4000+ RPM's from the cams, and the lightweight pulley helps a lot with passing and quick accelerations around town. It accelerates quicker, and hauls all the way to redline very easy! I noticed a lot more power at 4500+ RPM. The supercharger helps a bit to alleviate the power drop off up there but never seemed to enjoy redlining much. now it pulls even in the 5000's with plenty of power and torque like never before! That's the whole point of performance camshafts anyway, they add power at higher RPM's.
LCE Lightweight Crankshaft Pulley - This claims 2.7 acceleration horsepower per pound removed, and is 7.5 lbs lighter. So that's 20.25 hp gain of "acceleration HP" which is a made up term, by the way. In the real world, you notice this when stomping on the gas to pass on the highway, or going from a dead stop. Less rotating mass = more power to the wheels. It adds nothing as far as engine performance but rather frees up the engine to rotate the wheels, not the pulley. However it will still show up as a performance gain on a intertia-based dyno because of science and physics stuff. Since I had to take the crankshaft pulley off anyway for the timing belt, it was a no-brainer. Easy bolt-on performance.
Colt Cams 262 degree 5VZ-FE Camshafts - These are dyno tested to gain 22 HP, and I can guess where! My engine pulls much harder at 4500-5500 RPM's and loves to redline. I need to get this on a dyno soon to see if there's extra power to bump up the redline to 6,000 RPM's but not sure. There's not really much as far as gains in the 2k to 4k range, so if you are looking for some extra torque down low these are not what you want. These cams gain power by slightly changing the intake and exhaust timing, I'm talking maybe a couple of degrees difference. Side by side the stock cams are almost identical until you look hard. It idles a little rougher than stock but combined with extra lift on the intake side over stock, provides some nice power in the upper RPM's.
This was a VERY involved job. As a few people on here also have bought them so hopefully I can provide a few tips to help in the process.
First off, you will need a digital caliper to measure the valve shim thicknesses. This is not optional. Second,
a valve adjustment job is a must and you will need to custom order shims from Toyota since the exhaust valves WILL be out of spec. The shim spacers provided from Colt Cams are not quite thick enough to provide the right valve clearances (printed on the sticker under your hood). I needed to buy 9 of the 12 exhaust shims, 3 of them I was able to swap around to bring them into spec. Only 3 intake valves were out of spec initially and swapping shims around fixed all 3. Shims cost $15 each, so I was out $135 just for those.
When you fit the shim spacers supplied by Colt Cams in and you go to check the clearances, rotate the cams one complete revolution before measuring the gaps. I noticed that the oil in between the spacers and buckets would actually cause the reading to be off until it was pressed by the camshaft lobe at least once. Almost pulled my hair out thinking I had ordered the wrong size shims. Also, you will not get the clearances perfect. Since Toyota only makes them in 0.05mm increments (i.e. 3.00mm, 3.05, 3.10, etc.) it's hard to always get the perfect size. When it doubt, for exhaust valves go a little too big instead of too small. Exhaust valves will widen over time so having the gaps a little smaller initially will get you more life out of your exhaust valves.
Give yourself plenty of time to do this job. I had to remove the stock cams, remove all shims, install all shim spacers, measure all shim thicknesses, put in the new cams, check clearances and write it all down, then remove all cams, then order new shims, then install new shims, install camshafts, measure all clearances, remove exhaust camshafts, swap a few shims around, install camshafts again. That process took me about 8 hours. This is NOT an easy job nor something to be done by first time DIY mechanics.
I realize that this is the only real review of 5VZ-FE camshafts on the internet. These are the same camshafts that were offered by Sea2Sky tuning, Geoff at Colt Cams made this grind for that shop. The shop closed but Geoff still has the grind and told me he's been selling quite a few lately. Please feel free to PM me for any questions on installation or anything else related to these camshafts.
And yes, I am getting this thing ready for another dyno run!
